Results 11 to 13 of 13
    Oct 2005
    North Central Indiana
    782
    All calibers. Don't have it sorted yet. I bought and made 5 reloading presses back in the 90's when we went thru this stuff then. I just bought some more presses. Going to build some too now that i have a machine shop to make the rams...Bob
    Democrats don't seem to understand how knowledgeable, tooled up and inventive folks in the United States are.
    Sep 2009
    South Carolina
    571
    Nice rest, looks similar to one I made a several years ago. Probably stronger than mine also.
    The 7mm Magnum I had made scrap out it. The long section looked like a bow and the back stock area bent.
    I underestimated the force of the recoil. The thought was to be able to shoot one round then set back up where the cross hairs was when the shot went off and adjust the cross hairs to the bullet hole.
    Never worked, the 7mag knocked the rest all over the table. The more you tried to hold it seems the worse it was.
    I bet they are sweet for lighter calibers tho. Nice job, one of the best looking one's I've seen.
    Oct 2005
    782
    Thanks for the compliment Hardrock40. I have rubber caps that slip over the steel feet but I'm sure a 7MM will move it around. I actually built it heavy for sighting in my high power springer air rifles.
