Results 1 to 10 of 11
    Default maxstar 150 stl trouble.
    I was wondering I'd I could get someone to e-mail me a good picture of the inside wiring of a miller maxstar 150 stl I traded for this welder and outside cover, and both ends had been taken off to blow out and clean. I put both ends back on, but need a photo of how to plug all the wires back in. I don't want to hook them up wrong and fry it.
    Sep 2012
    seaford de
    406
    Can't you look at the diagram either in the manual or on the inside of the cover? You can download a manual at millerwelds.com under resources. If you can't get what you need from that... Let me know tomorrow and I will take the cover off mine and take some pics for you. Its about time it gets a good cleaning and waxing. I just tried meguires plastic and vinyl restorer on the plastic of a couple of my machines and then used rubbing compound and wax on the painted metal and they turned out great. Maguires is some really good stuff. They look new....q
    Oct 2004
    Edmonton, Alberta
    7,658
    Sounds more like the unit is roasted already. Who the heck is going to strip it right down to blow it out. Likely its a parts machine. Even if really there are no useable parts inside of it.
    Sep 2012
    seaford de
    406
    Quote Originally Posted by cruizer:306085
    Me. I do it to all my tools/equipment. That's why my equipment outlasts other's equipment that gets neglected... and they still look new or like they did when I first got em. And just judging from your comment... are you saying its not even worth trying to put it back together?... he should just assume that its not usable because the cover is off?
    Aug 2010
    Los Angeles
    1,165
    If that is a late model maxstar, there is no reason to remove the cover to blow out.
    I also believe that something more than just a reassembly is in order. I would send it out to a repair facility for diagnosis, and or proper reassembly.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Sep 2012
    seaford de
    406
    Quote Originally Posted by shovelon:306090
    Every time i pull the cover off of my maxstar it is very dusty inside. Since it is only two screws...why not. When you blow it out through the vent slots it really doesnt do much cause that part is boxed in separatly, so to actually clean it out u need to pull the cover.
    Sep 2012
    seaford de
    406
    Here are some pics. Of what it should look like
    Sep 2012
    seaford de
    406
    Another
    Aug 2010
    Los Angeles
    1,165
    Quote Originally Posted by weldonwelding View Post
    Yeah, you got me thinking about that. I may pull the cover off and see what is in there.
    Anyhow this maxstar was pretty disassembled. More than a clean I imagine.
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Thumbs up all i needed
    pictures worked, hooked wires up same as in your picture. machine works perfect....
    thanks weldonwelding!!!!!
