Results 1 to 8 of 8
Thread: Flashing
    Mar 2013
    14
    Default Flashing
    Need a idea how to flash or excite ( blue star generator welder).
    alabama
    751
    Wow, so much comes to mind on this but I dare not say anything for the fear of being kicked off the site.
    2- XMT's 350 cc/cv
    1- BOBCAT 250
    1- TRAILBLAZER 302
    1- MILLER DVI
    1- PASSPORT PLUS
    1- DYNASTY 200 DX
    1- MAXSTAR 150 STL
    1- HF-251 BOX
    1- S-74d
    1- S-75DXA
    2- 12-RC SUITCASES
    1- 8-VS SUITCASE
    2- 30 A SPOOLGUNS
    Jul 2010
    Four Flags city
    304
    I would think it has an exciter circuit so flashing isn't needed.
    Mar 2013
    14
    Default Flashing /blue star 185 welder generator.
    Thanks big mike it's blue star 185 welder generator done everything I know but still no voltage...
    Jul 2010
    Four Flags city
    304
    Post a serial number and I have a feeling one of the tech guys can help you.
    Mar 2013
    14
    Default Flashing
    Ok I do that.
    Mar 2013
    14
    Default Flashing miller blue star 185
    Miller blue star 185 /Generator welder.
    serial # LK030017R.
    May 2009
    Muskogee Oklahoma
    245
    Quote Originally Posted by Stone View Post
    serial # LK030017R.
    You need to flash the SR2. Use a 12 volt battery, positive of the battery to the positive of the SR2 rectifier, negative to negative. Wire 110 is your positive and 122 is your negative. All you have to do is touch one of the leads to the proper terminal of the rectifier. Don't clamp it on there. Start it up and see if you have OCV. If not then repeat the process.
