Results 1 to 8 of 8
Thread: cruizer help
    Nov 2011
    Edmonton
    43
    Default cruizer help
    Took my Trailblaer 325 in with 49 hours because it was acting erratically and flashing things on the screen. Picked it up Saturday and headed back up to work. Now here we are Tuesday and this piece of **** is acting up again. Screen is flashing again and says TMPI open across the screen. Maybe it's time I took it back and traded it for a Ranger 305...
    8,018
    Were you running it hard cause thats a temp issue.
    Nov 2011
    Edmonton
    43
    Running a grinder at excel power
    8,018
    That explains the inverter high heat. Excell is handy, for other stuff, not so much for grinding. Most inverters and thats all it is, don't care much for grinders. Lets avoid Excell. The unit should work fine, if you just let it the inverter cool down, then turn it off and restart it.
    Nov 2011
    Edmonton
    43
    Appreciate the help ! I'll give that a try tonight
    8,018
    Well, does the unit work ok??
    Nov 2011
    Edmonton
    43
    No still glitching. Ran it for 10 minutes this morning and it was ok
    8,018
    Soooo, are you going to use it or are ya going to switch it out.....
