Results 11 to 12 of 12
    Aug 2004
    Milan Michigan
    1,797
    Manisoba,Thanks for the clarification.
    Nov 2007
    Central Idaho
    203
    Default Welding table and cylinders
    With regard as to whether or not the cylinders need to be upright, I think that is only true with acetylene. It may be recommended that others be upright, but from my experience over the last 6 years with this set-up, I don't see why.
    This table is in use 5-6 days a week and I have not had any problem with the regulators. They sit back far enough that they are not exposed to anything that might be dropped or swung. I do have to be careful, though, to keep the lenses pointed down when I am welding - otherwise they get slag pits.
    I now have 3 bottles - argon, 75/25, and tri-mix. I have a Y connector on the back of the machine that lets me switch gases without having to disconnect and re-connect every time I switch processes.
    Not every table is right for everyone, but this one has worked very well for my small business.
    Thanks for looking, and thanks for the comments.
