Results 1 to 10 of 12
    Nov 2012
    West Central Mountains
    29
    Default Multiple Gound Leads
    I picked up a large all steel welding table that will be my primary shop work surface for stick, HF TIG and MIG. Should I ground the table? Can I leave the ground leads to my welders attached to my work table while using other machines--in particular the HF TIG?
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    Not quite sure of what you are asking?? You kinda have two questions mixed into one.
    Are you asking about all the work (ground) clamps remaining attached to the table when using the other machines or are you asking about grounding because of HF interference/transmission??? Or are you asking about both??
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    Nov 2012
    29
    I am asking about both. Should the table be grounded (to an earth ground, not a system ground) and can I leave one machine's work cable attached to the table while using another machine on the same table. I don't want to damage the electronics in my mig and inverter tig/stick machines. I have earth grounded my steel shop building skin for HF in prep for a higher output tig.
    Aug 2004
    Milan Michigan
    1,798
    You can have all the ground leads hooked up to the tableand weld with all the machines without any problem.
    Gounding the table to earth will help eliminate HF interference with electrical appliances in the shop and office, If I remember right, Cruizer said something about wraping tyveck around the torch lead, You will need to verify that one however.
    Nov 2007
    Central Idaho
    203
    Default Grounding
    What he said. Attached is a picture of my table. I have concurrently grounded the Passport Plus, Plasma Xtreme 375 and Maxstar 150 (not seen) without any problem. Note also that the table is mounted on rubber casters.
    By the way, I got the idea for a table made from channel from this site a few years ago. It's a great improvement over a solid plate table because it is not easily affected by warping, and if one piece does warp (as has happened), it's just a matter of replacing that one piece. Also, it allows for clamping anywhere on the table and allows me to cut plate or sheet on the table itself.Welding table 2.jpgWelding table.jpgWelding table 3.jpg
    Sep 2009
    South Carolina
    571
    I'll be looking for some channel now. Seems I remember a post about it but had forgot. I like that table.
    Sorry for the hijack
    Nov 2012
    29
    Thanks for the input. Mike, that's an interesting setup. Do you use the gas bottles while they are horizontal? I am under the impression they have to be vertical (top side up).
    It wasn't tyvek it was zip tying the first 5 or 6 feet of the work leads together off of the machine
    Jan 2013
    28
    Quote Originally Posted by mikeswelding View Post
    Table is a neat idea,but the bottle set up looks a little scary,dont you worry about the regulators getting snapped,looks like a co2 and an argon/mix maybe they are not as exposed as they seem.Diffently utilizing the space well.
    Sep 2009
    Colorado
    223
    Default Ground it
    Interesting to research something. Sometimes you find out that you are wrong. I had thought that it was a good thing that the secondary of the welder was isolated from ground.
    However, according to these articles, the worktable should be connected to earth ground. They reference an ANSI standard.
    http://www.millerwelds.com/resources...d-maintenance/
    http://www.lincolnelectric.com/en-us...ty-detail.aspx
    I would note that the Miller article says that cylinders should be upright, not on their side
    Richard
