Results 1 to 7 of 7
    Jul 2008
    Delhi, Ontario:
    1,984
    Default Help- Ranger 8 Died !
    Cruizer, Help !
    I was out on a job this morning, when the engine just died. ( Fuel Tank Full )
    I Took the gas line off the electronic fuel pump, & no gas was comming out when it was cranked.
    So, can I take it off & clean it, or is it a sealed unit ?
    If it's shot where can I get another one ?
    Ranger 8- Serial#- 10110 U1940808484
    .........Norm
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - DeWalt Chop Saw .
    8,101
    Onan, or Honda? doesn't matter much as neither had a electric fuel pump in that era. Now if it does, the power for it would have been routed through the oil pressure switch. So either the pump has crapped out, little oil in the engine, thus no oil pressure, or the wiring to the pump has come off.
    Jul 2008
    Delhi, Ontario:
    1,984
    Cruizer, It's a Kohler CH18S engine, 625 cc. - spec. 62514, ser.# 2422116047.
    It says electronic fiel pump on the side of it.
    Oil & filter change last week.
    I don't see any loose wiring.
    ...........Norm
    - LN-25 Wire Feeder
    - Spoolgun.
    - DeWalt Chop Saw .
    Sep 2012
    seaford de
    406
    One of my old welders had that engine, I don't remember which welder but it had the same problem. I took the fuel pump off and apart then gently cleaned it with carb cleaner then put it back on and it worked fine.
    Jul 2008
    Delhi, Ontario:
    1,984
    Thumbs up Back to work !!!!!!!!
    Weldon, Thanks. It's a sealed unit, No chance to take it apart as far as I can see.
    I went to NAPA. auto parts, just to check if by chance I could get a universal electronic fuel pump, I lucked out, they had one. $82.50 after tax.
    I installed it, & it fired right up first try !!!!!!!
    Now I can go back & finish the job I started today !
    Back on the road again .
    ........Norm
    - LN-25 Wire Feeder
    - Spoolgun.
    - DeWalt Chop Saw .
    8,101
    OK, if that pump runs to the right side kohler cylinder head, then just take it out of the circuit Plumb around it, cut the wires to it. It's only there for priming the one in the head, and thats for real high altitudes.
    Jul 2008
    Delhi, Ontario:
    1,984
    Cruizer, See post above !
    I'm Not plumbing anything, It's been fixed- New fuel pump !
    ..........Norm
    - LN-25 Wire Feeder
    - Spoolgun.
    - DeWalt Chop Saw .
