Page 1 of 5 12345 LastLast
Results 1 to 10 of 46
    Oct 2005
    North Central Indiana
    782
    Default Anyone gotten cracks in their shops concrete floor from using red heads
    Anyone gotten cracks in their shops concrete floor from using red heads to hold their welding table down. I'm afraid to drill holes in my 10 year old floating 4" floor for fear of bringing on cracks.
    It's only cracked down the sawed crack joints so far.
    Oct 2007
    Cave Creek Az
    1,051
    Mine is on wheels, so no problem. Red head don't really cause cracks unles they are very close the the edge of the concrete. If you are worried about it just use some all thread and concrete epoxy
    Feb 2012
    Wa
    633
    I have set thousands of wedge anchors, you should have no problems. I use them on slab on grade applications, foundations, retaining walls, etc. Everything anchored in my shop is with wedge anchors. What do you mean by floating floor?
    Epoxy is crazy expensive and I only use it if it is an engineered spec. Wedge anchors are cheap as dirt and fast.
    Oct 2005
    782
    Quote Originally Posted by walker View Post
    Thanks Walker, I'll look into the concrete epoxy, if I have to drill holes in the floor at least there won't be any radial forces generated from fasteners.
    Oct 2005
    782
    I have set hundreds of wedge anchors, you should have no problems. What do you mean by floating floor?
    Cgutto6 the pad was poured over 6" of compacted 3/4 stone and fines, it moves up and down when the ground freezes.
    Feb 2012
    Wa
    633
    Interesting, been building houses forever and that's a new one for me. I'm from Washington state and have never encountered that. With that said I would still just use wedge anchors and be done with it. No need to buy the epoxy dispenser ($50 for a crap Simpson one, close to a bill for a good one), and a tube of epoxy ($30+) for four hold downs.
    Oct 2005
    782
    Could you recommend a size and length for such a job? I put one of those pickup truck cranes on the table so it needs to be fastened down pretty good. 500 lbs max would do it. Thanks
    Feb 2012
    Wa
    633
    1/2 or 5/8 if you really want it held. Bed it 3 1/2" into the Crete.
    Dec 2012
    Simcoe Ontario
    103
    Rather than epoxy try pl premium construction adhesive works great I mounted a handrail into armour stone with that and all thread. Solid as you'll ever want for a table
    Apr 2013
    4
    I wouldn't mind a redhead in my shop, not sure what the wife would think though...
