    Milton PA
    39
    Default Commpressed gas tanks
    Is it possible to buy used/expired gas cylinders?? I would love to build a giant windchime.
    Frank aka The Weekend Welder
    3,948
    Yup. Check with your local welding supplier or call some scrap yards. I have bought some off of the scrap man. Bob
    PA
    369
    weekend welder,
    If you visit a local welding distributor and they may be a bit reluctant to let you have one or more, you could offer to bring a big hammer and cold chisel or a grinder and destroy the threads so it can't be used again.
    This assumes they have already removed the valve.
    I have 2 scrap 277 cu ft cylinders which were used for oxygen.
    Both have no valves and one has the bottom 3" cut off so it may be useful for your project.
    I was planning to make a big gong just like you but got distracted so I would be happy to give them to you.
    PM me if you want them - FOBO - "free or best offer"
    I am about 15 miles west of center city Philadelphia.
    Sep 2012
    seaford de
    406
    Quote Originally Posted by Burnt hands:305851
    weekend welder,
    I also have a couple of those size oxygen cylinders, they make really nice sandblaster tanks
    Sep 2007
    Medford MA
    542
    Note that acetylene tanks are filled with stuff in which the acetylene is dissolved.. Stick with oxygen and shielding gas tanks
    Cave Creek Az
    1,048
    If you can't find one cheap and fast, just buy a piece of pipe and and a weld on end cap. Weld, grind flush and you are in business.
