Results 1 to 8 of 8
    Sep 2008
    25
    Default Dynasty settings
    looking for a good set up on 3/16 steel like the pulse n stuff like that any help?
    Aug 2010
    Los Angeles
    1,168
    Quote Originally Posted by themayor View Post
    You should not need pulse for material that thick. Especially if you have a 200dx. Pulse will compromise the heat input too much for plate like that.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Sep 2008
    25
    so keep everthing to stock settings
    Aug 2010
    Los Angeles
    1,168
    Sure. Simple DC works very well.
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Sep 2008
    25
    What do I adj if I want a thinner bead width
    Aug 2010
    Los Angeles
    1,168
    Grind a different geometry on your tungsten, and or bleed helium into your argon flow.
    Pulse on the other hand tends to flare the arc IMO, however that is just my observation and could be BS.
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
    turn up frequency
    Default Mayor
    Quote Originally Posted by jarred.chance View Post
    turn up frequency
    Unfortunatly, Adjusting output frequency will have no effect in DC, only AC. High pulse settings up above 150 pulses per second can help narrow up and focuse the arc off the end of the tungsten resulting in a narrow weld bead. High pulse rates will also produce a nice ripple effect in the bead.
    Dave Malliet
    Applications Tech
    Miller Electric Mfg. Co.
