    Sep 2009
    South Carolina
    571
    Default 240v engine drive receptacle
    I just don't get it. The engine drive also has the four blade receptacle. I have not used that fourth blade in any configuration. What is it for and when would you need it?
    I am making extension cords for the 211 and dynasty, they don't use it so should I just ignore it on the engine drive also?
    Nov 2012
    Northern Arizona
    548
    Yep. Those are 14-50R and I made an adapter to go from 14-50 to 6-50. I have all my machines running a 6-50 on single phase 240v. Just find the two hots and the ground. The 4th is a neutral. If you run 4-wire SO cord you can make a little portable subpanel and break out a 115v circuit to run a grinder or something. I don't know about the code supporting that use, but who knows. 240v runs all the power through the hots and the ground wire is just there in case there is a ground fault. That way the electricity can go somewhere intentional.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Sep 2009
    South Carolina
    571
    "If you run 4-wire SO cord you can make a little portable subpanel and break out a 115v circuit to run a grinder or something."
    Ahhh, so that make's sense. Very good, thank you.
    1,914
    As I understand it the 4th lug is used as the common/white for a 115 circuit. It was put there due to the newer appliances needing a 115 circuit as well as a 240 circuit.
    Please correct me if I'm wrong on this.
    2,942
    You can make yer own adapter or buy one
    http://www.amazon.com/Hobart-770674-.../dp/B003J8NMF0
    Miller also has a version but more $
    the 14-50 receptacles also make feeding power to your house a lot easier
    Nov 2012
    Northern Arizona
    548
    Glad I could help. I cost me about $40 to make a 6ft conversion extension with 8ga. I had the the same day for abnout the same cost as oljne and no shiping. Whenever I take my welder to a new place with a different outlet I test the outlet and the make an adapter cord. It works well.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    226
    If you have a rv place close they have some good 50 amp adapters 4 to 3 prong .
    2,942
    Quote Originally Posted by Kpack View Post
    Those usually only provide 120 power from the 14-50 receptacle because there isn't anything on an Rv that is 3 wire 240v.
    They us the adapters for rigs that are 30 amp 120v but want to or need to use a 14-50 receptacle
    226
    Yes I didn't think about that . I usually make up my own on the welder . I forgot those rvs are from 50 amp to 30amp 120 v .
