Results 1 to 3 of 3
    Apr 2013
    Hawaii
    3
    Red face Millermatic 175 wire doesn't feed
    I am appealing to any welding machine repair experts out there or anyone who has had a similar problem and solved it. My Millermatic 175 mig doesn't feed wire. I checked for power at the feed motor and measured 0.9vac. I tried connecting 12vdc to the feed motor and it ran so I replaced the pc board. Still no wire feed. the contactor is working and I have weld current output, does the main transformer provide current to the drive motor? I've also tried plugging in a new M10 gun with no luck. Does anyone know what the correct voltage to the drive motor should be?
    Any help would be greatly appreciated
    8,095
    Disconnect the drive motor and with a resistance meter check for 2 ohms or less between the red and black leads, and check the leads to the motor frame which should be high resistance
    8,095
    As for input motor voltages it, kinda depends on the serial# of the machine
