    1,919
    Default Cat backhoe wheel
    Found these pics in my file. The guy ran the machine with the rear wheel loose for a while & opened up the lug holes pretty good. Rather than weld them up & redrill or weld & die grind I opted to just make a new center pc. & weld it in.1201020847.jpg1204021646.jpg1204021648.jpg1210021743.jpg
    Looks like a nice fix to me! My old employees did that to an old bobcat of mine.
    Aug 2004
    Milan Michigan
    1,881
    MMW, How do you know that you have it pefecty centered, I would be concerned about a high speed wobble at about 12 MPH
    1,919
    I used my self leveling/balancing/centering welding wire to make sure it is good.
    I tacked a plate across the center hole, measured in from different spots on the rim to find the center. Center punched it & used my circle cutter on the plasma. Laid out the new center, cut the id/od with the circle cutter, punched holes & welded it in.
    Aug 2004
    Milan Michigan
    1,881
    That was not an easy job to get all the spacing right so my hats off too yaaa.
