Results 1 to 7 of 7
    turbo38t Guest
    Default Question for a buddy looking to weld on the side....
    This is kind of a tricky one. My buddy has his own condo so he can't weld there. He has a barn at his parents but it doesn't have good enough power for a welder and his father doesn't want him to wire it up for welding. So....basically he wants to MIG weld with a budget. He went to WTTI but realistically only TIG welds for a living now. It's probably 150 feet to the barn so a 110v extension cord is outta the question. Is it within reason to run say a Hobart/Miller 140 or 180 amp mig off of a medium sized generator? It wouldn't be used all the time but for side projects. If so any recommendations for a decent generator that won't break the bank? He is looking to get into it with a welder, generator(or other suggestion) and a couple of tools for under $2000. I'll be helping him with the projects and such and I know a 140 amp machine will be enough although it may require a little extra work. Thanks for any replies. Dave
    Dave where abouts in jersey are you? Joe
    turbo38t Guest
    I'm in Hazlet......my buddy is in bedminster
    Quote Originally Posted by JMK WELDING View Post
    Im in Lincoln Park a little far. Your friend needs a generator that is cv/cc otherwise the welder even like a millermatic 140 wont perform correctly. Small generators will have a power surge. He would need to know what welder he is buying and match it to a genny. Better yet he should go to a welding supply center and ask them.
    May 2011
    Bossier Parish La.
    547
    He could look into getting a used Bobcat or Trailblazer(or other engine drive) and be stick welding right from the start and have power for power tools. He could add a spoolgun later for MIG off the BC/TB too, they can also be equiped to TIG. Then he could go where ever he wanted to and weld. No need for seperate welder and genset, it's an all in one machine.
    May 2011
    Bossier Parish La.
    547
    Did your buddy ever make a decision about any of these suggestions?
    Oct 2005
    North Central Indiana
    782
    I can vouch for Northern generators... I have two of them powered by 16HP Vanguard engines, they have been reliable machines for about 7 years or better. I replaced their motorcycle batteries with auto batteries and battery boxes from NAPA. They always start during the winter now. I keep a trickle charge on them all winter just to be safe . I just started one of them yesterday to give it some running time.
    http://www.northerntool.com/shop/too...ble-generators
