Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
  1. #21
    Default Storage of solid mig wire
    If you are going to use a bat insulation go with a stone wool product like roxul. Water runs out of it if it gets wet, Is fireproof and mice and rodents won't chew it.
  2. #22
    Wa
    625
    I would use rigid insulation. As thick as you can fit and keep inside the framing. I would use plumbers tape or something similar with self tapping sheet metal screws to hold the insulation in place. Then install 6mil plastic sheeting over the entire inside. Then hang sheetrock. You may have to add some drywall backing before insulating. I like Sheetrock due to its low cost, fire resistance, and most is white so adds light to the shop (can be easily painted if not white). Obviously you would have to do all inner wall work before all of this ie electrical. You can do this same process to the ceiling.
