    Sep 2009
    South Carolina
    571
    Default Another trailer coulper question
    Trailer couplers are thin and strong which leads me to think they may be a bit harder material.
    I read the thread where some use bolts and most weld.
    I have a coupler lock where a ball is inserted in the ball space and a U bold is pushed down through the extended sides of it. Its yellow so you guys have probably seen them.
    I haven't settled on what I'll use, this came with the trailer. I watched a video where this lock was easily defeated with a pry bar by prying the U bolt over the hump.
    So would welding a short bent piece of 1/2" round on the hump above the ball weaken anything critical? If not it would prevent prying that U bolt over it.
    Below is the type of lock but the weld will be over the ball area on the coupler.
    1,914
    I would not hesitate to weld something to a coupler like you are describing.
    Illinois
    635
    I use a piece of schedule 40 pipe with two chains attached [top and bottom] to slide over coupler end and lock around tongue. Cheap but it's something. Battery grinder and cutting wheel will cut through almost anything.
    Oct 2005
    North Central Indiana
    782
    Would it be hard to build either a 2", 2 1/2" or 3" square tube slip out tongue held in place by a slip bolt with a covered lock like on a gang box.
    Remove the hitch and weld a plate across the top and bottom of the rails and weld a SQ tube receiver to it.
    Sep 2009
    South Carolina
    571
    I have thought about a removable coupler and know some who cut the tongue off and reinstall it when in use. Don't want to do that just yet.
    My idea was crap. I have this one lock pick I keep around just in case. When I went out this morning to weld a piece in the way so that thing would pry over the hump, my key wouldn't open the lock.
    Turns out it wasn't on right and the latch was in a bind. However, I got out the pick and with no effort it fell off. I'm not good at lock picking. Just a simple master lock can beat me sometimes so this thing is a joke.
    I like the pipe idea, I know you guys have secrets, lets hear some more.
    The video should be here in a few minutes.
    Well trying to change format so it will work try this link.
    http://youtu.be/JJMh3kiqo6o
    Oct 2005
    782
    something to get things started
    Sep 2009
    South Carolina
    571
    Quote Originally Posted by tackit View Post
    Nice would work on my boat trailer but my enclosed is like V shape.
    Oct 2005
    782
    Just take off the V ball hitch and cut off the rails far enough back to accommodate a bottom and top plate with the receiver tube. The rail loss can be made up on the length of the slip tongue.
    Sep 2009
    South Carolina
    571
    That one I'll give some thought, Thanks
