Results 1 to 8 of 8
    turbo38t Guest
    Default Hobart Handler 140 .023 roller part #?
    Hey guys. I just bought my bro a gas bottle and .023 wire for his new Hobart Handler from Tractor Supply. I know these machines are essentially a millermatic 140 machine but made a bit cheaper. Does anyone know the part number for the drive roller for .023 solid wire? Thanks. Dave
    Houston, TX
    900
    Should come with a combination .023-.030/0.35 roller. You just flip it around to go from .023 to larger wire. If it has a feed roller, it's probably the right one. You can download the manual here.
    http://www.hobartwelders.com/om/0900/o925f_hob.pdf older model w/4 taps
    uses 202 295
    http://www.hobartwelders.com/om/6digit/o258267a_hob.pdf new model with 5 taps
    uses 037 338
    3,928
    http://www.millerwelds.com/om/t225716g_pt_mil.pdf
    18 . . . . . . . . . . . . . . . 220 179 . . ROLL, feed .024, .030/.035 .
    Doesn't your roll have 2 grooves? One side for the .023 and the other for .030-.035?...Bob
    Houston, TX
    900
    Bob, is that a Miller PN? The ones I found at Hobart are different numbers.
    3,928
    Quote Originally Posted by cope View Post
    Yes it is...Bob
    2,908
    The new 140s come with an .030/035 drive roll
    .o30 for solid wire
    .035 for fluxcore
    Drive roll chart
    http://www.hobartwelders.com/product...0-187-210.html
    turbo38t Guest
    This....the .035 side is a toothed groove while the .030 side is smooth...I think I ordered the right one from cyberweld today.....we shall see.....seems the miller rolls are narrower than the hobart?
    .o30 for solid wire
    .035 for fluxcore
    Drive roll chart
    Houston, TX
    900
    Quote Originally Posted by turbo38t View Post
    Hopefully you ordered a Hobart roller. The Miller may well be a different part.
