Results 1 to 10 of 12
    Mar 2012
    Southwestern Ontario
    44
    Default hooking spool gun to TB
    Just Curious what is involved with running my spool gun off my TB 302? The spool gun is a miller as well thanks
    108
    Thanks for asking this question. I also have a TB 302 and have often wondered what would be involved to hooking up a spool gun. I have an older Miller 185 spool gun, and most likely it will be too outdated to use with a TB............I will be watching this post for more information............thanks.
    3,950
    http://www.millerwelds.com/products/...gun-chart.html
    Don't know if you can adapt other spool guns or not as i don't know enough about them. I too have a Spoolmate 185 and it looks like a 3035 don't know if its the same...Bob
    wisconsin
    116
    Quote Originally Posted by rustymfg@hotmail.com View Post
    What spool gun do you have?
    Aug 2008
    Thetford VT
    64
    You need a WC24 control 14 pin to TB and spool gun plug on the other end.
    Chad
    Trailblazer 302
    Suitcase 12 RC
    S22P-12 Feeder
    HF-251-2
    Spoolmatic 30A
    Maxstar 200 DX
    Shopmaster 300
    S-22A Feeder
    Coolmate 3
    Trailblazer 250G
    A wc-115 would allow you to hook a 30a or 15a to any power source including the tb
    A spoolmatic 3 will direct connect to the tb
    To properly answer the op, we need to know what kind of spoolgun you have
    Dec 2011
    424
    I expect that with the 185 spool gun you would need the SGA100C. I have a 185 that works with a SGA100C. I see that the 3035 is also used with the SGA100 so I suspect they are the same as the 185. That may also include the 3045 which I think is a 3035 with a heavier barrel(= higher duty cycle?). Compare the parts list and manuals of all three to verify. For the original poster yes, one would need to match the spool gun adapter to the spool gun, which is ......? -----Meltedmetal
    Mar 2012
    44
    The one I have is a canox mini-mig 30 amp made by miller to my understanding hope this helps thanks for any input
    Cave Creek Az
    1,051
    I can run my 3035 off of my TB251 with my SGA100c, in fact I can run if off of any of my CC/CV machines with that box.
    Dec 2011
    424
    Default canox mini-mig 30 amp
    Maybe a few pics of your spool gun would help someone identify it. I can't find much online about Canox equipment or that model. Is it 30 amp or is it a miller 30A painted red? 30 foot lead?--Meltedmetal
