    Dec 2011
    20
    Default Can I use a push pull mig gun on a 76 series wire feeder?
    His guys I would want to know if I can use a push pull gun on the 76series wire Feeder.its actually connected on a Xmt 350cc/cv powersource
    8,252
    A 76 series, never heard of that one, However say if you had a s-74mpa plus with a xmt 350 mpa, then yes
    Dec 2011
    20
    Yes you are right the wire feeder is a 70 series 24v.
    No
    a xr gun will not connect to a 70 series feeder.
    But you can connect a xr feeder and xr 30a to your Xmt
