Results 21 to 30 of 33
  1. #21
    WY...armpit of U.S.A.
    659
    Nicely made holder. I have to ask...why not just use your mill to true up the square tube?
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
  2. #22
    Jul 2009
    Australia
    1,031
    Hi Roy,
    Exactly.
    The mill would have been better alround but it was the only square stock I had hanging around to test the new chuck.
    It needed squaring for another project and I found out I needed this indicator jig to use the chuck so it all worked out.
    Ji
    Grip it and Rip it
  3. #23
    659
    Makes sense in oh so many ways! Looks like it's about time to invest in a finger style indicator for your lathe work. I've a number of old lug back plunger indicators, but a finger style is so much easier to use on a tool post.
    EDIT: Actually, I find a Noga brand mag base indicator holder invaluable.
    Miller DialArc 250
    Logan 7" shaper
    Ellis 3000 band saw
  4. #24
    Jul 2009
    Australia
    1,031
    Hi Roy,
    I have one of those lever type indicators but for squaring square it only moves a little bit before end of travel while the dial type has heaps to avoid the corners. May be there is a better way but I have not been shown it.
    Thanks Ji
    Grip it and Rip it
  5. #25
    659
    If it works for you, that is the only thing that matters. I've been known to plop down a section of 1" flat stock across the lathe ways and sit a surface gauge on top to rough align stock in the chuck before bringing out the indicators.
    Miller DialArc 250
    Logan 7" shaper
    Ellis 3000 band saw
  6. #26
    Jul 2009
    Australia
    1,031
    Hi Roy,
    Have you got a stock stop for your mill.
    When rounding the corners I marked a line on my vice so I could spin the part but have it align again without adjusting the X,Y,Z.
    Ji
    Grip it and Rip it
  7. #27
    659
    Quote Originally Posted by Jigantor View Post
    Hi Roy,
    Ji
    Stock stop...no. I use either a clamp on jaw stop on the Kurt vise or wind down a long T-bolt on the table next to the vise and work with that for a reference.
    You should be able to modify your new indicator holder to work on the mill table to catch the front edge of the work you need to mill to get the work piece indexed. See below...
    Miller DialArc 250
    Logan 7" shaper
    Ellis 3000 band saw
  8. #28
    Jul 2009
    Australia
    1,031
    Hi Roy,
    Wow is that your mill? Pretty cool stuff. I thought about bolting something into the tee slots. I was thinking about making a permanent stop fixed to the vice. Something to index a part from both sides of the vice.
    Ji
    Grip it and Rip it
  9. #29
    659
    No, not my mill...just a quick and dirty Google photo search result. Here's my old gal. shop%20pics%20019.jpg
    Miller DialArc 250
    Logan 7" shaper
    Ellis 3000 band saw
  10. #30
    Jul 2009
    Australia
    1,031
    Still a good looking mill.
    Well built machinery seems to work forever.
    Ji
    Grip it and Rip it
