Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    Dec 2012
    Sweetwater, TX
    201
    Scales would be as follows
    40-130A range (each step is 10 Amps)
    1 - 40A
    2 - 50A
    3 - 60A
    4 - 70A
    5 - 80A
    6 - 90A
    7 - 100A
    8 - 110A
    9 - 120A
    10 - 130A
    60-160A range (each step is 11.11 Amps)
    1 - 60.0A
    2 - 71.1A
    3 - 82.2A
    4 - 93.3A
    5 - 104.4A
    6 - 115.5A
    7 - 126.6A
    8 - 137.7A
    9 - 148.8A
    10- 160.0A
    80-225A range (each step is 16.11 Amps)
    1 - 80.0A
    2 - 96.1A
    3 - 112.2A
    4 - 128.3A
    5 - 144.4A
    6 - 160.5A
    7 - 176.6A
    8 - 192.7A
    9 - 208.8A
    10 - 225.0A
    100-250A range (each step is 16.66 Amps)
    1 - 100A
    2 - 116.6A
    3 - 133.3A
    4 - 150.0A
    5 - 166.6A
    6 - 183.3A
    7 - 200.0A
    8 - 216.6A
    9 - 233.3A
    10- 250.0A
    Not having one in front of me this would only be the case if the knob only goes down to 1 and stops and up to 10 and stops. If it goes below 1 like to a 0 value or higher than 10, then I would need to recalculate the steps.
    northern NJ
    1,928
    Quote Originally Posted by Darrren Bartlett View Post
    thanks everyone for the help! only question i have left is on my machine for the amps it just has one through 10. What does 50 mean? how do i figure it out? Am i missing something on the machine? below is what my machine looks like. thanks again!
    The knob on the right is the fine adjustment. It is a percentage of the middle knob. #1 = 10% # 5 = 50% #8 = 80% etc. of the middle knob range.
    So if you set the middle knob at 100-250 amps, that gives you a 150 amp range. each number would be 10% of that range starting at 100.
    If you set it to 40-100 then the range would be 60.
    MM250
    RCCS-14
    thanks everyone for the help!!
