Results 11 to 16 of 16
    Oct 2005
    North Central Indiana
    782
    I'm more of a Fred Flintstone CNC machine type.
    http://www.youtube.com/watch?v=J1NGaZZkTn8
    Cave Creek Az
    1,040
    Hey Jim, do you know how units like the gotorch that use hand held torches trigger the plasma on and off? I have done some reading and I can't find it. Thanks.
    You wire it into the trigger switch wiring inside the machine. The PC video manual has a pretty good list of machine specific directions, as well as instructions to figure out and wire just about any machine there is. It is not that hard.
    Jun 2012
    22
    Yes....they just have a simple two wire interface that has to be spliced into the torch trigger switch circuitry. The output of the GoTorch machine closes a set of relay contacts that does the same thing as activating the trigger switch on a hand torch. The go torch also has two more wires that connect to the DC voltage output inside the plasma cutte as well.....it monitors the voltage for use with the optional torch height control functions.
    Jim Colt
    Sep 2009
    Canada
    189
    That's done 2 ways.
    If you have the CNC interface on your plasma cutter, just plug it into the control box. If you don't have the CNC interface on your plasma cutter, you can splice into the on/off wires going to the torch and make your own cable to connect the plasma to the control box of the CNC.
    Miller Bluestar 2E
    Thermal Dynamics Cutmaster 52
    Torchmate CNC table
    Ironworker Welder
    Operating engineer
    Sep 2009
    Canada
    189
    Jim beat me too it.
    Miller Bluestar 2E
    Torchmate CNC table
    Ironworker Welder
    Operating engineer
    Wa
    621
    Thanks for the replies guys.
