Results 1 to 8 of 8
    Nov 2012
    Northern Arizona
    544
    Default ESAB Coreshield 8
    Has anyone ran this before? The wire I am looking at is 1/16" I believe. I was thinking of picking it up to run in my MM251 for the occasional job where I need it. I usually run 035 htp 70s6 wire and c25 gas. I don't have too much experience with fluxcore so I figured I would ask this group.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    3,951
    be carefull if you have a M-25 gun as the fluxcore 75/25 combo will fry your gun if not carefull. I use it everyday and she gets hot....Bob
    Nov 2012
    Northern Arizona
    544
    I do have the m25, but I was thinking that as it is setup with a smaller liner for solid wire I should just get something like a q300 for the bigger fluxcore so I don't need to worry much about changing liners. I think the coreshield 8 is selfshielded as well.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    not near you
    148
    Coreshield 8 is a completely different animal from the E70S6 wire you have been using...It takes a different technique to run in all positions.Mainly used in structural steel fabrications that require a seismic rated weld filler...
    Lodi, CA
    1,305
    Go to the Lincoln website, read up on innershield wires, especially NR-232. It's a T-8 wire like Coreshield 8. The ESAB product is much more user-friendly than 232, but needs to be run the same way. NO WEAVING. Also remember, most T-8 wires will NOT run thru a MIG gun and liner, the liner is just too light and wippy for a stiff wire, sometimes you can never get a good consistent wire feed because of the drag. There's a reason for more expensive flux-core only guns.
    Feb 2005
    N.E. SD
    1,381
    Coreshield 8 is defineitely easier to run than 232. That being said, it likes to be run hot and fast, and I don't know that a MM251 could handle 1/16.
    I would suggest NR 211, which can be had in .035 and .045
    Jeff
    1,912
    You will overheat your 251 & gun running 1/16" wire. Try .045". I like Hobart fabshield 21B or my second choice is Lincoln NR212.
    Nov 2012
    Northern Arizona
    544
    Thanks for the help. I decided to pass. It was a good deal which is why I was asking about it. 25# for $50 or possibly $40. I'll look into some .045 wire, probably fabshield.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
