Results 1 to 5 of 5
Thread: MM211 o-rings
    Feb 2012
    Pembroke Pines, FL
    34
    Default MM211 o-rings
    I have a MM211 and I change between the spool gun and the standard gun. It's a tight fit going into the welder. I noticed today one of the o-rings was torn. Is there any recommendations for lube on these o-rings?
    Houston, TX
    900
    Oct 2009
    Reno, NV
    299
    Loctite brand Silicone Lubricant (their part number is 51360) may be just what you need...that number is for a 5.3 ounce tube and is something I keep in my toolbox for use on rubber stuff that needs some kind of slickum on it.
    Don J
    Reno, NV
    Never pick a fight with an old guy. Old guys are too smart to fight and get hurt. They'll just kill you and get it over with.
    Dec 2012
    Memphis, TN 38133, USA, Earth, Milky Way
    62
    Use a very thin coat of high-quality silicone grease like NAPA Sil-Glyde, Ford Caliper/Dielectric, or Ford Electrical.
    I also use it on my bottle fittings to help prevent tiny leaks & prevent corrosion/seizing.
    Feb 2012
    Pembroke Pines, FL
    34
    Great input, thanks guys.
