Results 21 to 30 of 33
Thread: big no no!
  1. #21
    Oct 2009
    Reno, NV
    299
    Well, whatever you guys figure out is the right way to weld or not weld on any particular truck frame (and I have seen a bunch of stuff done in a bunch of ways...some ugly, but workable, some just WRONG and some right), the weld in the picture looks worse than some of the ones the newbies at the local tech college make! ( Gee, I hope that doesn't hurt anyone's feelings )
    Don J
    Reno, NV
  2. #22
    S.W. Missouri
    155
    Quote Originally Posted by weldonwelding View Post
    Thanks.. but your talking to probably the only person You have ever talked to that is state certified to weld on the states fleet of trucks about welding to truck frames. You do not weld to the flange of the frame... attached is a pic of a sticker that states just that on the truck that I'm working on. But don't worry, your not the first person that I've heard not know that
    Just for clarification. Where that sticker is placed is not the flange that is the face, the vertical part, the flanges are the top and bottom horizontal edges.
    But still don't like to weld anywhere on a heavy truck frame if its avoidable.
    Trailblazer 302
    Lincoln SP-135-T
    Hobart Stickmate AC/DC
    Smith torch
    Spoolmatic 30A
  3. #23
    Sep 2012
    seaford de
    407
    Where the sticker is... is the web. Good lord man.. it seems every post on here turns to a pizzing contest. I posted this with the intentions that some could relate but I see very few do.
  4. #24
    Jul 2008
    Flin Flon & Creighton area
    233
    Default repair of frame bracket.
    Hello all, I have to comment, that there are several posters that are correct here. I do agree with weldon's initial original post , with the pictures he provided. The welds are rather crappy looking down hands. Depending on exactly where and what the joint is holding can have very important issues as to the lifespan of the frame. I also agree that there shouldn"t be any welding on the web of a frame member, but i have also seen engineered frames from manufacturers that contradict this. In a perfect world the component should have been drilled and bolted , or possibly riveted together my the manufacturer. I also realize that the world isnt perfect and most of the time additions and attachments are made to already existing frames, vehicles and equipment. Whatever needs to be attached is sometimes done hastily without much consideration to the negative affects of welding and its related heat input issues. I seem to be a bit puzzled about the sticker saying no welding to the channel or is it beam flanges ? I have seen several manufacture specs that ok this as opposed to welding on any web areas. I think most of us here would agree that taking a extra minute to dress or grind welds often can be all it takes to make a good repair that much better.
    I have a welding addiction
  5. #25
    Apr 2012
    Western Pa.
    301
    Default big no no!
    Pictures are ok but they really don't give a clear picture of welds and or overall job & load. I've taken pictures of my good welds & they didn't look that good, taken pictures of bad welds & they didn't look that bad. Go figure ??
    If I'm guilty of one thing it's over building & over welding, just don't want to be responsible for someone getting hurt on my watch.
    One thing I've learned no one knows better than the one under hood, and if its a job that can take someone or more than one mans life it better be 100% + Just no room for error. I think we should trust his judgement. And I don't think the owner is going to pay to have it redone if he didn't see a problem.
  6. #26
    4,457
    The world would come to a stop tomorrow. Millions of incompetent people work on equipment every day.
  7. #27
    Default What were you thinking?!?..
    Just out of curiosity?! Why would you weld Vertical down with 7018... not that you cant do it, I can as well but would never weld anything load bearing that way.... not bashing you but you were welding this on the derrick of an oil rig?... not a lawnmower. If that weld fails, and it could very possibly, will you write the check for the funeral of hospital bills? Just saying... To me the right way to do it, based on the pictures would have been to grind both down to bare metal and then put a few passes on up hill, if ya wanted to get really technical about it, put the first pass on, chip it, wire wheel it, and then overlap two passes over the top of it. That a way your getting a good tie in to both pieces of base metal. Hope this didnt come across rude.
  8. #28
    Oops misunderstood the post.... Sorry!
  9. #29
    Sep 2012
    seaford de
    407
    Quote Originally Posted by Missouripipewelder:306325
    Nah... Jus came across as you didn't read a whole lot before you commented. I do it sometimes too..... Cause sometimes peoples comments are just too long and boring. Funny though, what u said is what the post is about...lol
  10. #30
    Right on brother, I just joined this forum, I'm a Lincoln guy, mainly because I contract for the North Dakota Oil fields. That being said my my rig trucks got a 300D pipeliner on it. I have an ESAB 150 tig/stick and a Maxstar too. I read you whole post and just misunderstood ya. That monorail projects seemed pretty cool based on the pics. I'll be putting pics up and updating my profile so if ya get a chance check my rig out, its my baby... probably went way overboard but oh well! Take it easy.
