Results 1 to 10 of 12
    Apr 2013
    Default weld 22ga floor patches
    I'm attempting to weld in some 22ga floor patches. I'm using a 135 mig with .023 wire and co2/argon mix. when I attempt to tack the patch I'm burning the patch away. I have the voltage turned all the way down and the speed at about 2 1/2 and I'm working in a overhead position. I would appreciate any tips or comments.
    try using a backing plate, something other than the material you are welding. Try a piece of aluminumon on the back side of where you are welding. put a weight on it to hold it flat against your surface. This will take some of the heat out of your weld and allow you to weld without burning through.
    Mar 2013
    Southeast N.M.
    8
    Ceramic works really well as a backing plate too.
    Wa
    661
    How are you adding the patch? Overlaying or cutting and fitting? How large is the patch? Is any of the material rusted? I have done lots of welding on my friends 22g Sheetmetal on his car using .023 and 75/25. Fit up is very important. Gaps make life much harder. I was using my mm180.
    Stitch weld it.
    1,919
    Fit up is very important on thin material. If your overlapping they need to be tight together. Use tacks instead of trying to run a bead. Tack about every 3/4" then fill in with more tacks. If butt welding you shouldn't have any gaps. Make the patch first then scribe around it & cut out the bad area.
    As was mentioned already a backer of some sort helps a lot also. Aluminum or copper work well. Everything needs to be clean & solid. No half rusted areas.
    Sep 2012
    seaford de
    407
    From what I gather your just laying over existing..? Start your tack on the existing metal and bring it to the metal that's burning away
    Apr 2012
    Western Pa.
    328
    Yep. Agree with Weldonwelding, start your tack on base metal and or the thicker metal & flow into patch. Same with running bead
    Oct 2005
    North Central Indiana
    783
    Why can't you use thicker steel for the patch?
    Apr 2010
    The Peoples Republic of Southern California
    80
    Using a flanger with the hole punch is great for panel replacement
    You punch the holes and plug weld the replacement panel in place where you flanged the original metal it creates a lap joint that fits flush
    But it does not work for all situations pics wold help
    Backed my CATMA over your CARMA
    OOP"S clumsy me
    What would SATAN do ??
    Miller Digital Elite (new)
    Jackson EQC master (old)
    Miller Trail Blazer 302 Air Pak
    Spectrum 625 Extreme
    Suitcase 12RC
    Evolution Rage 3 saw
    Craftsmen Atlas 12X36 Lathe
    Half a ton of tooling
    Rusty old truck
