Results 11 to 14 of 14
    Dec 2012
    Sweetwater, TX
    201
    Did you do any joint prep? If I want a flat appearance I have found it helps to make a place for the weld. So I will usually throw a little bevel on each edge then weld.
    Only prep was taking a brush and knocking off anything loose dust from the new material.
    Wa
    643
    Quote Originally Posted by clint738 View Post
    Try to bevel the two pieces and I think you will be happier with the appearance.
    Dec 2012
    Sweetwater, TX
    201
    Did not bevel. Just knocked the sharp edges off with the grinder, pushed them against each other and tacked then welded out.
    Never thought of beveling 1/8" since it is already sort of thin.
    How much land should be left, or down to a point?
    Wa
    643
    On 1/8 a bevel of less than 1/16 should be plenty. You are for sure able to get full pen with no bevel, I have just found if you are looking for a flatter look a little bevel helps.
