Results 1 to 10 of 10
    Sep 2012
    seaford de
    406
    Default what grade of gasoline recommended?
    New bobcat with kohler 23hp. Regular, mid grade or?
    Oct 2005
    North Central Indiana
    782
    Did it come with a Kohler owners manual? It should be in there or I would call Kohler and talk to them. All gas today contains some alcohol so I wouldn't let it set in the machine to long.
    Feb 2013
    12
    I run high grade in my 2011 model - try to get it somewhere that dont have alot
    of stuff in it
    The main thing is not to panic or get excited
    Bobcat 250, MM 211
    B&D,Meltabo,Milwaukee
    Porter Cable,Dewalt,Makita
    Harris,Airco
    Ingersoll-Rand
    Evolution Rage 2
    40 AMP Plasma
    Sep 2012
    seaford de
    406
    Everywhere around here is 10% ethanol. Used to be up until about a year ago you could go to Maryland just 10 minutes away and get clean gas but now its 10% too. I was thinking mid grade but I was also thinking too much octane would make it run hot. I'm gonna look in my manual when I get home
    Dec 2012
    Sweetwater, TX
    201
    I wonder if the engine welders do well with fuel stabilizer additives? I've heard they help prevent some of the carb issues if fuel with ethanol sits in a carb too long.
    Sep 2012
    seaford de
    406
    With my old welders I always put a little Lucas fuel treatment in the gas. They all still run pretty good so I guess it doesn't hurt
    Oct 2006
    Illinois
    594
    We run regular with sta-bil year round in the 250 Bobcat and 302 Trailblazers. No issues .
    Oct 2005
    782
    Quote Originally Posted by weldonwelding View Post
    Lucas is good stuff by this fuel additive chart. intresting info on fuel additives.
    http://fueltestkit.com/is_gas_additi..._e10_list.html
    Feb 2012
    Wa
    531
    Octane rating has zero correlation to engine or combustion temps. It's purely a measurement of knock resistance. I would run what the manufacture recommends.
    When all else fails read your manual, says 87 octane minimum. Gas up to 10% ethyl alcohol, 90% unleaded is acceptable, E15,20&85 should not be used.
