Results 1 to 10 of 10
    Sep 2012
    seaford de
    407
    Default what grade of gasoline recommended?
    New bobcat with kohler 23hp. Regular, mid grade or?
    Oct 2005
    North Central Indiana
    782
    Did it come with a Kohler owners manual? It should be in there or I would call Kohler and talk to them. All gas today contains some alcohol so I wouldn't let it set in the machine to long.
    Feb 2013
    14
    I run high grade in my 2011 model - try to get it somewhere that dont have alot
    of stuff in it
    The main thing is not to panic or get excited
    Bobcat 250, Extreme 12VS, MM 211
    Meltabo,Milwaukee, Porter Cable,Dewalt
    Victor O/A, Ingersoll-Rand
    Evolution Rage 2, 40 AMP Plasma
    Sep 2012
    seaford de
    407
    Everywhere around here is 10% ethanol. Used to be up until about a year ago you could go to Maryland just 10 minutes away and get clean gas but now its 10% too. I was thinking mid grade but I was also thinking too much octane would make it run hot. I'm gonna look in my manual when I get home
    Dec 2012
    Sweetwater, TX
    201
    I wonder if the engine welders do well with fuel stabilizer additives? I've heard they help prevent some of the carb issues if fuel with ethanol sits in a carb too long.
    Sep 2012
    seaford de
    407
    With my old welders I always put a little Lucas fuel treatment in the gas. They all still run pretty good so I guess it doesn't hurt
    Oct 2006
    Illinois
    643
    We run regular with sta-bil year round in the 250 Bobcat and 302 Trailblazers. No issues .
    Oct 2005
    782
    Quote Originally Posted by weldonwelding View Post
    Lucas is good stuff by this fuel additive chart. intresting info on fuel additives.
    http://fueltestkit.com/is_gas_additi..._e10_list.html
    Feb 2012
    Wa
    656
    Octane rating has zero correlation to engine or combustion temps. It's purely a measurement of knock resistance. I would run what the manufacture recommends.
    Mar 2011
    101
    When all else fails read your manual, says 87 octane minimum. Gas up to 10% ethyl alcohol, 90% unleaded is acceptable, E15,20&85 should not be used.
