Results 1 to 2 of 2
    Sep 2009
    Key Largo, FL
    24
    Question Fleck in my welds
    You all you goods guys out there.
    Starters: Dynasty 200 DX, 2006 year. Doing 3/16" Al. Using 3/16" x 1 1/2" angle mill finish. 1 /1/4" pipe butt weld. Running 185 amps, 70 bal 120 frq. all good. I'm guessing 6000 series. Problem was went to Anodized pipe kicked to 200 amps , 70, 130. full of pepper flacks. I tried gas at 20 to 35 cfh or what ever. Welds look fine just dirty. 3/32" 1.5 Lanthaitd tried orange and red.
    Any Help Out There??
    Aug 2010
    1,163
    Those are chunks of anodized finish on the top of your beads. You need to completely clean the area of the weld to eliminated those.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
