Results 1 to 2 of 2
    Jun 2011
    New Milford ct
    75
    Default Airco Heliweld 5 any info
    I think this is made (was) by ESAB, one is up on CL 250amp. guy wants a bit than its worth but the adds been reposted for a few weeks. Is this a square wave machine? Any good with TIG aluminum? Also I would think if something blew parts might not be available.
    PA
    355
    Here are scans from an old catalog.
