Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    Feb 2012
    225
    I'm trying to help the no load hz looks good rpm good. Is there a way to to check fuel delivery when you load it . I mess with a few generators and sometimes under a full load I have to open the main jet a little bit even though its fine with no load. But I don't know diesels to good but I guess it could be fuel delivery. Is there a good way to clean the injectors or any kind of setting on the pump that you know how to do without causing problems. Maybe some linkage hanging when it tries to load and ask for fuel. I'm just trying to think of the simple stuff . When you load it try to watch your linkage or move it by hand see how it sounds and feels.
    Mar 2013
    Southeast N.M.
    8
    Would it be fairly accurate to load it up and watch the rpms? And does the throttle solenoid have two set positions or will it compensate slightly like cruise control? I will check tomorrow after work and let you know what it's doing. Thanks.
    Feb 2012
    225
    Just be carful don't do anything rash maybe cruiser or somebody may get in .
