Results 1 to 10 of 12
    Jun 2012
    Tracy, CA
    221
    Default Syncrowave 350LX or Dynasty 350
    Looking for some feedback from the experienced here.
    I'm trying to decide between a Syncrowave 350LX and a Dynasty 350. It will be for the shop but there isn't any production to speak of yet. In each case I'll be looking at the TigRunner Complete. I have experience with the Dynasty but the Syncrowave is about $1188 cheaper.
    Pros and Cons on each will be helpful.
    Thanks.
    Lincoln Vantage 400
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic 350P Aluminum
    Millermatic® 252
    Syncrowave 351
    Lincoln LN-25 Pro
    Multimatic™ 200
    XR-Aluma Pro Gun
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Victor Oxy/Acetylene Set
    Aug 2010
    1,184
    Pros only.
    Dynasty. Half the power draw, thus half the service requirements.
    High speed pulse.
    Independent en,ep setting.
    4 wave profiles. TriWave for beercan welding.
    Smaller utility bills.
    Smaller footprint.
    Synch. Cheaper initial investment.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Nov 2010
    265
    A couple of more pros for the Syncrowave
    Proven design for a very long and reliable service life.
    Simple controls for a TIG machine.
    Jul 2010
    386
    Quote Originally Posted by Dipsomaniac View Post
    +1
    Also:
    At 250A:
    • Sync350 has a 90%+ duty cycle
    • Dyn350 has only about a 30% duty cycle.
    (To get down to a 30% DC on a Sync, you're going to need to get up around 400A.)
    Oh, and the Sync has a 30+ year record of proven performance and reliability <shrug>
    Don't try that with a Dynasty boys and girls
    "But wait! We'll save seven cents on the light bill!"
    God knows beercan welding keeps us going 9 months out of the year.
    (Heck, you can weld beer cans with a sine wave machine.)
    Jun 2012
    Tracy, CA
    221
    Thanks guys.
    I knew shovelon would go for the Dynasty. I really like the duty cycle of the Syncrowave and the lower investment. As far as power consumption, I guess it's only consuming power when it's turned on. And if that's the case.... It must be making money. Of course with a 1,000 sq ft shop, the smaller footprint of the Dynasty is nice too.
    Hmmm. What to do...
    Lincoln Vantage 400
    Miller Dynasty® 350
    Millermatic® 252
    Syncrowave 351
    Lincoln LN-25 Pro
    Multimatic™ 200
    XR-Aluma Pro Gun
    Diversion™ 180
    Mar 2011
    torrington, connecticut
    22
    Default synchrowave
    have a synchrowave at shop (#11 to be delivered by zane weldcraft) been in use constantly since early to mid 70's. only repairs have been 1 circuit board and foot pedal resistors and replaced foot pedal cable (phisical damage). power hog but absolutely bulletproof machine. (we also have dynasty 200 for small intricate work-been problem free so far) will not be replacing the synchro 300 anytime soon.
    Aug 2010
    1,184
    Dynasty. PROS
    3 phase input current capable. Allows for 1/3rd power bill of tranny tigs.
    Blue Lightning arc start. Set per tungsten size or custom configure start sequence.
    Tungsten life is double of tranny tigs while welding alum.
    Smaller tungstens required.
    Smaller cups required when welding alum, consumes less gas.
    Faster alum puddle formation. Uses less gas.
    Faster alum travel speeds. Uses less gas and power per foot of welds.
    Faster alum welding. Greater productivity per hour of welding. Higher profits.
    John Marcella switched to Dynasty. Better control and prettier welds. Puts out video.
    Up to 5000 pps pulse arc for high speed seam welds on Stainless or any other thin metals.
    Better pulse puddle agitation of syncs annoying 10 pps. All are default and usable until altered slightly.
    18 set and forget memory stations.
    PFC included.
    Default parameters are easy to understand and use right off.
    Less dependence of Helium while welding thick alum.
    Direct replacement to Miller AeroWave.
    ROI incredibly fast unless collecting dust.
    Dynasty Cons
    Higher intitial investment.
    Very light and portable, not theft deterrent.
    Friends will bug you to use your machine.
    Latest technology, learning curve required.
    Syncrowave. PROS
    Heavyweight tranny machine. Somewhat of a theft deterrent.
    Sync CONS
    Last memory only.
    Pulse only up to 10pps, virtually useless for high speed thin wall puddle agitation. Interferes with Autodark hood switching functions.
    Pulls 128 amps input power at full draw on AC welding. Twice that of Dynasty.
    Consumes more power than a Dynasty700.
    PFC is not included. PFC is available as an expensive option.
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Jul 2010
    386
    Quote Originally Posted by kvwall View Post
    If that's the case, you ought to take a look at some of the older stuff like a Miller 330A/BP.
    It goes up to 460A in DC TIG and 435A in AC TIG and to match its Duty Cycle capabilities, you would need a rotating pool of about 15 Dynasty 350s.
    You can also commonly buy one for less than $1000.
    Syncrowave. PROS
    Just so I'm clear, you don't think having more than TRIPLE the duty cycle of the Dynasty is a "pro"?
    Jun 2012
    Tracy, CA
    221
    Dynasty. PROS
    PFC included.
    Dynasty Cons
    Syncrowave. PROS
    Sync CONS
    Last memory only.
    That's a TON of pros. You may have persuaded me in the Dynasty direction. Now I just need a good deal. You selling any used? I could drive down to LA to pick up.
    Lincoln Vantage 400
    Miller Dynasty® 350
    Millermatic® 252
    Syncrowave 351
    Lincoln LN-25 Pro
    Multimatic™ 200
    XR-Aluma Pro Gun
    Diversion™ 180
    Aug 2010
    1,184
    Quote Originally Posted by Helios View Post
    Same duty cycle on 3 phase, but anyhow I got the Dynasty700. Wonder why they ashcanned the Syncrowave500?
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
