Results 11 to 14 of 14
    Dec 2011
    420
    We occasionally do a few for the local guys rebuilding stuff. We have a small machine with a 4 foot rotary table and are using round steel shot. Rims need to be degreased cause the shot will stick in the grease and the rim won't clean properly. I can put 4 car rims on the table at the same time and with 2 to 4 times turning the rims over it takes about 40 minutes or so to clean all 4. Rust and paint are usually pretty well all gone down to bare metal. They need primer fairly soon or they will rust again fast. Unfortunately I'm much too far from you to be of any direct assistance.
    Meltedmetal
    Sep 2011
    20
    Doesn't have to be steel, I made one out of an old wooden shipping crate. Put a lexan window in it. I was worried at first how long it would hold up, but it seems to be fine...
    Oct 2005
    North Central Indiana
    782
    Thanks Meltedmetal for the consideration. It's been to cold to open the shop up anyway. I got to wait another two weeks before I can put the tools back in the shop without them and the electricle tools getting rusty and covered in condensate. It's gets bad around here south of Lake Michigan. I use those GM donut tires for building yard trailers, I need to blast two rims. I'll probably use the suction blaster I got from NAPA with just a hose and gun and use black beauty.
    Oct 2005
    782
    Quote Originally Posted by 65-408 View Post
    I don't think the power I have would hurt wood either ....unless I stayed in the same spot.
