    Jun 2009
    Las Vegas Nevada
    132
    Default Diversion 165 being pushed?
    Just had an interesting thing happen I've never seen. There's a million things this beginner has never seen so I'll offer this one first.
    I'm building an alloy dry sump oil pan. I've seam welded all the .063 sides with some success, nothing to buy my retirement on.
    Today I attempted to weld this .063 sump to the 1/2 inch flange. I suspect it is beyond the capacity of the 165 but I thought I'd give it a try.
    First little 1.5 inch test seemed to work well.
    I brought out some C clamps and a bit of hammer to get it back into line and the second try went to **** immediately!
    The reduced section cup split and fell out leaving just the torch exposed?
    Is this typical and normal degradation or have I done something way wrong??
    Miller Diversion 165
    1966 Bridgeport Mill
    Leblond 15x 35 Regal Servoshift lathe
    Solberga SE 1425 Drill Press
    Bigass Bandsaw
    Hydraulic press
    small surface grinder
    Belt sander
    Tons of grinders and hand tools
    Knife edge Balancing rollers
    Heat and AC in the garage
    Jags and racing Triumphs
    Jun 2009
    Las Vegas Nevada
    132
    Well that ramble didn't make much sense did it?
    I was startled by the cup splitting apart at the transition at the large diameter.
    Do these things fail, an expendable piece? Like tungstens and filler rods should I be looking to replace cups on a regular basis? Or did I overheat, undergas something to cause this failure?
    Bigass Bandsaw
    Hydraulic press
    Belt sander
    I have had an experience similar with lava cups at higher temps if you don't have the tungsten out far enough. It's also possible the cup was already cracked and the heat from welding caused it to split.
    Jul 2010
    378
    FWIW, you can get gas cups (like most other things) cheaply on ebay.
    1,890
    Although not super common I have had pcs. of cups break away especially when using torches at max or beyond. Yes you are pushing the 165 & it's torch. Just get some spares & try to watch the duty cycle. Your torch if used like this will die prematurely but you do what you gotta do.
    I used a Lincoln tig 175 for a long time & welded stuff like you are doing. Went through a few torches but until I could upgrade it's what I had.
    Jun 2009
    Las Vegas Nevada
    132
    Watch the duty cycle is good advice! I notice the cooling fans running considerably longer now.
    I'm using a 500 Watt halogen lamp to preheat the area. Not sure how helpful it is but it helps cook my gloves a lot sooner! OUCH!
    I bought the Diversion specifically for this fabrication. Learning it is going slowly but it's going....
    I gotta go back to the books, I don't think my tungsten is out far enough.
    Bigass Bandsaw
    Hydraulic press
    Belt sander
