Results 1 to 10 of 10
    362
    Default Lincoln Classic III Carburetor
    I have a Classic 3 with the Continental TM27 gas engine and it needs carb work. It has old gas in it and it only runs with the choke on. Can anyone provide a link to a service manual for carb removal and disassembly?
    Oct 2005
    North Central Indiana
    783
    362
    Well I got it all cleaned up, inside and out. But now I'm thinking the electronic actuator may be toast. Is there a way to test it? Cruizer???
    8,351
    You mean the solinoid?
    Really that sea foam stuff clears the carb out without taking it all apart. No muss, no fuss
    362
    I don't think its a solenoid. It threads into the float bowl and appears to be an electro-magnet. I tested it and it is definitely faulty. Maybe I have an odd-ball engine/carb?
    8,351
    Are you talking about the GM engine or the continental. Big difference
    362
    Continental, with Zenith carb.
    8,351
    Quote Originally Posted by atc250r View Post
    Its merely a fuel shut down. It should click when 12 Vdc is applied to it, ie plunger gets sucked in, and shuts the fuel off when 12Vdc is removed.
    362
    Just what I suspected. I gave it 12volts, and nothing happened. Guess I will just get a plug for that open hole in the float bowl. Engine runs great when I remove the solenoid and plug the hole with my finger.
    Seems near impossible to find a new replacement solenoid...
    Sep 2012
    seaford de
    407
    Where are you located? Theres a guy i know that has dozens of these old machines sitting around for parts. He has @ least 2 of every large machine ever made by lincoln, miller, and marquette... im sure a few others too. And he also can order any part for any machine ever made. I am in delaware
