Results 1 to 3 of 3
    Sep 2011
    20
    Default Weld Cable Connector Question
    I have an old set of 2/0 weld cables and they both have an inline connector that I have never seen before, hoping someone can identify? Problem is that they have no name on them. Each side has four "fingers" that i assume are supposed to grab and engage with the fingers on the mating connector. The fingers are about 2" long and there is a rubber boot that covers the fingers that slightly accordions in when it touches the opposing boot when the connectors are pushed together.
    I assume that these are now obsolete, but wondering if they are OK to use. Any ideas?
    Houston, TX
    900
    Try it out and see. A picture might help also.
    1,890
    I would just put Tweco connectors on. Model MPC-2 will fit 2/0 cable.
    http://www.buyweld.com/2-mpc.html
