Results 1 to 3 of 3
    Philadelphia Pa.
    6
    Default 301d idle problem
    I have several 300d, and 301d welders I repair.
    ]The idle on some of them will not go back down. They stay on high idle. The man I replaced said he had replaced the pc boards and the solenoids. I am not sure if he did. Any ideas?
    8,006
    Unsure on your question, DO YOU REPAIR MACHINES? Do you want to repair machines or did you buy one that isn't working...
    A 300D is COMPLETELY different from a 301D
    Philadelphia Pa.
    6
    Default repair
    i repair machines. right now i have a 300d that will not idle down. i replaced fuse 5.
Tags for this Thread
