Results 1 to 3 of 3
    Feb 2013
    Canada
    110
    Default dynasty 200dx PLUGS
    Im very noob when it comes to electricity!
    Here ,i have a L630-p screw back on my welder(green in green, white in "x" and black in "x") so far so good???
    I have cut back the red one!the L630-p is a 30A,250v is that good enough?
    On my pigtail i was planning on having a female(L630-c hook exactly like my welder is except the black) and at other end will be a male 15A110v
    Also another pigtail made as an extension cord hooked up with (L630-p and L630-c)
    Am i ok???? Its been a little pain as even electrician dont understand...
    Let me know if anything here is wrong or ok thanks
    Feb 2013
    Canada
    110
    Revised :
    Here ,i have a L630-p screw back on my welder(green in green, white in "y" sorry and black in "x") so far so good???
    2,942
    That's sounds good
