    Default Flash burn is a B
    hey yall i have been a pipe welder/ tube welder for pushin 12 years i have been in some tight spots and had flash burn alot... im gonna let yall in on a secret if you dont already know!!! vicks vapor rub! put a little on your eye lids right before u go to sleep, it keeps your eyes watering and the worst burn will be gone in 2-3 hours. lemme know if you have to try it.
    Aug 2010
    1,170
    Quote Originally Posted by Waymack View Post
    Dang son, you are going to go blind soon. I think you need to make some adjustments in your approach.
    Vicks makes some sense though to keep them most.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Oct 2005
    British Columbia
    242
    Braver man than me. No way I'd put Vicks anywhere near my eyes. Mandatory safety glasses with sideshields and can't remember the last flash I had. The odd reflective burn on neck and ears from other welders in close quarters.
    well sometimes when your waded up in a ball in a tight spot u might accidently fire up a little soon before your lens is flipped from about 4 inches away... it sucks. or when tou got 8 welders jammed in a small area, it happens
