Results 1 to 3 of 3
    Sep 2012
    seaford de
    406
    Default question on hf box
    I just got a miller hf-251d-1, I am running it off my aead... it welds nicely. I am used to tagging aluminum without foot pedal or finger control but it would be nice. I see the of box has a 14 pin receptacle. Is it able to control the amps if I just connect the pedal to the of box? Or does it also have to run to the welding source?
    alabama
    743
    Must be connected to the welding source for amp control.
    2, XMT's 350 cc/cv
    1, XMT 350 vs
    1, TRAILBLAZER 302
    1, MILLER DVI
    1, PASSPORT PLUS
    1, DYNASTY 200 DX
    1, MAXSTAR 150 STL
    1, HOBART CHAMP
    1, HF-251 BOX
    1, S-74d
    1, S-75DXA
    2, 12-RC SUITCASES
    2, 30 A spoolguns
    Mar 2008
    Dallas,Tx
    172
    Default Aead
    In general, you simply connect the foot control to the HF and you are in business.That is the beauty of the Miller 14 pin system. On the other hand if your AEAD is old enough that the 14 pin receptacle is not there, you are out of luck as none of the normal Miller foot controls is compatible with the older AEAD's and it in addition would require wiring into the machine. weldersales
