Results 11 to 17 of 17
Thread: GMAW Aluminum
    not near you
    148
    If you are passing destructive tests OK....But....Could use more flow and fusion at the edges ....Ripples could be closer together.....I would use 5356 because The lift goes in the water...4043 turns gray and dull after exposure to water ... especially ocean water...I'm being highly critical here but that is what you get when you post a picture like that......Easy for me to pass judgement while I sit at the computer..I'm retired ......Good Luck
    Jun 2012
    4
    Default GMAW Aluminum
    Well I'm the lead fabricator,not the engineer. The print calls for 4043 so I use 4043. I thought it looked good,as did the engineer and the end customer.
    Sep 2012
    seaford de
    407
    Quote Originally Posted by Jayp156:304596
    It does look good man. Most of the people who criticise on here are on here all day..... And all night...... And usually they have a very long list of very expensive machinery under every post. So go figure, you can't make money welding if your sitting in front of a computer all day, so their probly just full of it or they have debt up to their necks. IMA go with their full of it
    Aug 2010
    1,184
    Quote Originally Posted by Jayp156 View Post
    Job well done. Satisfying the engineer is all that counts.
    4943 is just released last November at the Fabtech show in Las Vegas. The sample spool that I was given flows like butter and qualifies for use under your 4043. The small amount of magnesium provides some exothermic action to enhance penetration. I think 4943 would be a nice alternative to your 4043.
    http://www.maxalinc.com/files/QuickS...g_9-12_doc.pdf
    http://www.marinelink.com/news/paten...ces350264.aspx
    Nice work.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Apr 2013
    strafford, Mo
    Does the 302 have the synergic pulse feature
    Wow man that look like a machine did it!!!
    Jan 2013
    The designing on aluminum makes it attractive and more wonderful.
    Its shining gives the effects like shinning and polished gold.
