Results 1 to 10 of 17
Thread: GMAW Aluminum
    Jun 2012
    4
    Default GMAW Aluminum
    GMAW Aluminum. CP-302 with an XR-Control. 3/64 4043 wire,6061 T611 aluminum.1" to 1/2". 31V 370 IPM.
    3,861
    Real nice....Bob
    Wa
    487
    Dang. Very clean!!
    Dec 2009
    722
    Might as well tig it if you want that look. This jod looks like a lot of spot stitching.
    Look even though.
    Aug 2010
    1,158
    Very nice. Is that spot stitch?
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Aug 2004
    Milan Michigan
    1,633
    It looks good, However you should have used 53/56 on 6061 tube.
    I agree it looks like you stitched it, I worry less about the nice ripple and more on the good fusion.
    Jun 2012
    4
    Wow. Thanks the first 2 guys. Ok,it's not stitched,there is maybe two start/stops which are blended pretty well. Next,doing TIG on 1" to 1/2" would cost quite a bit more not counting the hours of extra welding. In a high production shop,that's just not feasible. Next,this is not tube it is 1" plate,1/2" plate and I-beam. I don't know why someone suggested 5356,this is a Boatlift and a brittle wire would make no sense. And no it's not pulsed MIG and no it's not too cold and yes we do destructive and non-destructive tests regularly. Always complete fusion and always passes.
    turbo38t Guest
    I thought 5356 was the go to wire for structural aluminum like 6061.....4043 I generally use on cast or repairs....
    Quote Originally Posted by Jayp156 View Post
    Jun 2012
    4
    We use 4043 instead of 5356 for several reasons; better looking welds (as all lifts have quite a few through bolts),we do occasionally weld 6061 to cast which 5356 can't do,more penetration(while not as strong as 5356,penetration is key when welding 1" plate without much of a bevel or chamfer),our winch heads have motors that get got and 5356 will corrode faster if it's past 150 degrees (I could be wrong on that),no hot cracking(in my experience),the list goes on.
    Aug 2010
    1,158
    You should switch to 4943 then. Bridges the strength gap between 4043 and 5356 while retaining the fluidity of 4043. Maxal makes it.
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
