Page 10 of 10 FirstFirst ... 5678910
Results 91 to 96 of 96
  1. #91
    Wa
    633
    What's a porta power ram? Never heard of it.
  2. #92
    Dec 2009
    722
    A porta power ram is a cylinder of different size that you hook up to either a hydraulic lever pump or air driven pump and you use it to push on anything you want to push. we use them to drive pins out of bores or 2 days ago we use 2 in tandem to push out a tumbler wheel of a P&H drill rig. Very handy when you need to push a jammed pin out of a bore.
  3. #93
    Sep 2012
    seaford de
    407
    Porta power. This one is made by torin big red. 10ton
  4. #94
    Sep 2012
    seaford de
    407
    Try this again. Pic didnt go thru on last one
  5. #95
    Wa
    633
    Right on. Thanks guys for the responses. Kinda what I figured based on the name but I had to ask.
  6. #96
    4,461
    There should be about a 5 page limit to a thread.
