Results 1 to 8 of 8
Thread: Mig gauge
    Mar 2013
    25
    Default Mig gauge
    Just purchased a 35 S welder and the gas line blew off at the regulator. I re-installed, this time with a clamp and then the other end blew off the solenoid end. I noticed that the gauge needle is buried and that's even with the knob turned all the way out. I figure the gauge is bad or am I adjusting it the wrong way. If the gauge is bad, where do I purchase a new one and what is the general setting of the gauge, for mig welding. Thanks, Tom
    Wa
    672
    Clockwise increases pressure on my regulator. I run between 12-25 cfh depending what I'm doing.
    Mar 2013
    25
    That's what I do, but the pressure seems like its ready to burst. It also is leaking air out of the small holes on the front side of the gauge
    Feb 2013
    Kansas City, Missouri
    11
    Diaphragm is ruptured
    Mar 2013
    25
    New gauge then
    Aug 2010
    1,184
    Or rebuild it.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Mar 2013
    25
    I didn't know they were re-buildable. I'll check into that tomorrow depending on how much a new one is. I don't want to put too much into a 1973 unit. It does work pretty well, well, as good as a novice welder can. Thanks for the input
    Aug 2010
    1,184
    Quote Originally Posted by concreteguy View Post
    Check with your LWS, or try these guys. http://www.regulatortorchrepair.com/
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
