    Default HOW To', Vertical Down
    Hi What is the right procedure for doing downhill welds?
    I find the molten metal running down under the arc & getting in the weld pool,
    Doe's it take more current to blow the slag out Or less to keep the heat down
    Any paticular rods suit better? I know vertical up is the way to do most joints But what is thr recommend , easiest way to go downhill in lighter material?
    Ive seen perfect pictures of the so called stack of dimes look,
    Anyone share the technique for doing this?
    Thanks" Joe,
    Sep 2006
    south west Michigan
    81
    Used to run 6013 downhill on thin (up to 10 ga or so) sheet stock in school.
    120 or 125 amps or so with an 1/8" rod. You have to be very careful at the start or you'll get a lack of filler on the face of the weld. Hold the rod about 60-70 degrees pointing uphill and go like heck LOL (no whipping or pausing)
    I'm sure some of the pipeline guys can tell you more about other rods and techniques. .
    Sep 2009
    Canada
    186
    I was never a fan of 6013 rod.
    To run downhill with stick, I'd use 6010 or 6011. Fast freeze rods make it a piece of cake.
    Miller Bluestar 2E
    Thermal Dynamics Cutmaster 52
    Torchmate CNC table
    Ironworker Welder
    Operating engineer
    1,868
    With stick watch your puddle closely & stay ahead of the flux. I only use it on thin material that will burn through if going verticle up.
    Dec 2012
    Simcoe Ontario
    91
    You can down hand 7018 as well you wanna keep your rod about 90 degrees to the steel and turn your heat up to approx the next rod size heat. Example if you run 1/8 normally around 120. Run 3/32 down hand at around the same. We use down hand 7018 for welding membranes to boiler tubes. And don't worry about the flux you'll burn it all away as you go.
    asheville n.c.
    618
    I use 7018 downhill occasionally to fill before running back uphill.
