Results 1 to 7 of 7
    Mar 2013
    4
    Default aluminum trailer questions
    Hello all
    I am wanting to build a aluminum trailer for atvs and side by sides.
    I need it to be about 6 foot from hub to hub and about 14 foot long.
    I just built a steel trailer out of 2x3x1/8" tubing. My problem is i dont know what equilevant aluminm thickness i need. So any ideas?
    Salem ,Ohio
    3,963
    Cool
    Figure twice as thick and wider tubing for 14'. Nothing smaller than 4" wide and at least a 1/4" thick. Just my thoughts....Bob
    Jul 2009
    Australia
    1,031
    It is half the strength so you would have to double the size of the members in every dimension. That said aluminium deflects 2/3 more than steel, welding removes any tempering for 2" from the bead and flexing will lead to fatigue cracking.
    By the time you account for all of this the cost will become a problem.
    Ji
    Grip it and Rip it
    Mar 2013
    4
    Thanks for the advise. I was thinking of going over to my buddys and measuring his 14' aluminum trailer. Is that reasonable?
    Salem ,Ohio
    3,963
    Cool
    Quote Originally Posted by rhino ak View Post
    Maybe. Is his a factory built welded one or a bolt together like these.
    http://www.trailex.com/ My family started this company in the early 60's....Bob
    Mar 2013
    4
    Quote Originally Posted by aametalmaster View Post
    no its a karavan welded trailer. I just built a tandem steel out of 2x3x1/8" tube, my thinking is if i built the whole aluminum trailer exactly the same just twice the thickness i should be ok?
    Mar 2013
    4
    [QUOTE=aametalmaster;304360]Maybe. Is his a factory built welded one or a bolt together like these.
    WOW those are some nice trailers!!
