Results 1 to 4 of 4
Thread: Slag Question
    Default Slag Question
    Hi
    While stick welding Can anyone explain why the slag comes to the surface?
    I was told that the slag is less dense and for that reason it comes to the surface, my next question was, Why would it come to the surface when welding vertical or over head?
    thanks
    Ido
    Jan 2013
    NE Illinois
    155
    My guess would be because the heavier metal displaces it.
    Aug 2012
    4
    The weld metal is electrically charged. The flux isn't. The metal is following the electric arc and trying to fuse with the base metal. The flux is pushed out of the way.
    Sep 2009
    Canada
    174
    Stick welding
    Flux come to the surface for a few reasons.
    The main reason is the flux covers the weld to shield it while cooling from nitrogen contamination from the atmosphere.
    The flux covering also help shape the weld bead while cooling.
    With some rods, the flux provides iron deposits to help increase metal deposition rate.
    Lincoln Idealarc 250 stick/tig
    Miller Bluestar 2E
    Thermal Dynamics Cutmaster 52
    Torchmate CNC table
    Ironworker Welder
    Operating engineer
    Owner/Operator Devlin Metal Works
    Custom CNC Plasma Cutting and Welding
