Hi
While stick welding Can anyone explain why the slag comes to the surface?
I was told that the slag is less dense and for that reason it comes to the surface, my next question was, Why would it come to the surface when welding vertical or over head?
thanks
Ido
Thread: Slag Question
03-21-2013, 10:45 AM #1
- Feb 2012
- 11
Slag Question
03-21-2013, 11:07 AM #2
My guess would be because the heavier metal displaces it.
03-21-2013, 11:18 AM #3
- Aug 2012
- 4
Slag Question
The weld metal is electrically charged. The flux isn't. The metal is following the electric arc and trying to fuse with the base metal. The flux is pushed out of the way.
03-23-2013, 05:43 PM #4
- Sep 2009
- Canada
- 130
Stick welding
Flux come to the surface for a few reasons.
The main reason is the flux covers the weld to shield it while cooling from nitrogen contamination from the atmosphere.
The flux covering also help shape the weld bead while cooling.
With some rods, the flux provides iron deposits to help increase metal deposition rate.Lincoln Idealarc 250 stick/tig
Century Mig
Thermal Dynamics Cutmaster 52
Torchmate CNC table
