Results 1 to 10 of 11
    Nov 2012
    10
    Default need some advice
    I having a problem with my vertical up 3/8 open root pass using 3/32 7018. I keep it about 80-90 but I keep burning through, or I get little penetration on the back side. I know I'm post to run a stringing, but am I missing here?
    why are you running a root with a 70/18 shouldnt you be usin a 60/10 or puttin your root in with tig?
    northern NJ
    1,914
    Your amps seem slightly high to me.
    MM250
    RCCS-14
    Nov 2012
    10
    that what the instructor wants us to do. I said the same, referring to the book.
    Oct 2005
    North Central Indiana
    782
    Open root I would think you should be using a fast freeze rod like 6010 or 5P. Have your instructor make a weld and watch how he does it.
    I Z my way up, hesitating on the sides long enough to tie in and fill the crater then I jump across the middle, the middle takes care of itself.
    Nov 2011
    Edmonton
    43
    1/8 land 1/8 gap 75 amps 6010 rod, use stepping action
    Oct 2005
    British Columbia
    242
    Long time ago did the 7018 root thing. It was good practice for stainless stick root. They're very similar and lo-hi is cheaper. 3/32 land and gap and use a wedge to maintain opening. I believe 70-75 amps, maybe lower. When doing these uphill roots, instead of straight on, try pivoting rod angle towards alternating lands......about 30 degrees.
    Sep 2012
    seaford de
    407
    I have taken 5 structural tests 2 were AWS. I have never used 6010 on the root...only on pipe. You just turn the heat up a lil bit and whip it in.
    Nov 2012
    10
    thanks ill give it all a try. the instructor there at community college sucks, getting info from him is like pulling teeth.
    Structural test 7018 in the open root. No backer??! What's the code?
